If you have a all round knife and use the knife for all types of work, the sharpening angle can be something like 22-26 degrees, straight or convex is a matter of taste. I prefer convex edge for this type of knife.
If you have a knife specially and only for woodwork, the angle must be exact. 19 degrees is a nice angle for soft wood and 22 degrees for hard wood. It is also a matter of taste if you use 19,5 or 20 degrees for softwood, and also a matter of how much power you like to use.
So, the answer depends on what you are using the knife for. All round knife, the angle can change, a knife you use for cutting in wood, the angle must be exact.
Convex edges cuts better in nearly all material then a straight edge do, but not in wood. If you work with wood, use straight edges with perfect angle along the blade.
Many people discuss type of edges, straight or convex and what type of edge is the best. It is also depending of the use of the knife.
Axes with straight edges, we call the carpenter axes, is for cutting along the wood fibers. Axes with convex edges is to cut across the wood fibers and also splitting wood.
If you use a straight edge and try to take down a tree, the axe fasten in the wood, a convex edge do not fasten, it bums out again - if the curve on the convex edge is ok.
If you try to use a axe with convex edge as a carpenter axe, you must hold the axe in a angle that the power from the stroke goes in to the wood and it can spoil your work. With a straight edge, the angle of the axe make that the power goes downwards, in the direction of the edge, and cuts out a fine slice of the wood.
The sharpening angle of the edge of knifes works similar. For wood work you must come close to the wood. Compare with a plain steel angle.
Some of the oldest knifes have chisel edge. That means that there was different knifes for left and right handed people. With that type of edge you can use your knife as a plain steel. Other knifes have 15 degrees on one side of the blade and 5 degrees on the other side. The edges was design for the purposes of the knife.
Then, some blacksmith start to produce knifes in industrial scale. Why do different knifes for left and right handed people? He put the edge in the middle one type fits all! It works nice today because we have got use to that but we do not work so much in wood at they did before.
Thomas
