sharpening convex in the woods?
Finally KGD and I disagree about something!!! I'm neurotic about keeping my edges sharp. I keep a small homemade sharpener in a ziplock bag my pack.
I just stapled some thin foam on one side and stapled some fine sand paper on top of that. It's a portable mousepad. :)
On the other side I glued a scrap of leather (red!) and impregnated it with stropping compound.
I made two of these, the one pictured is the larger. The smaller one is about 6" long and weighs next to nothing. This little block will keep a convexed edge hair-popping sharp and was made with scraps from around the house in about 10 minutes plus time for the glue to dry.
Look's like the Ideal setup, You get the Slack Belt result's with out the High Dollar equipment plus you get a Strop, Great Homebrew Sharpener Rotte, Perfect for the Convex Edge, And the Price Is right, Thank's for sharing the picture's and your Ingunuity,
I have used my leather belt at home and in the field it works great ,it helps if you wear a heavy leather belt and your knife just needs a little help. I have never done it but I would just get a flat piece of wood(baton a 2" thick straight branch) rub some stones together to make some fine grit and rub it into the wood and there you go a fairly coarse strop then you go to your belt to polish.I will have to try this next time I am out to see how it works.
I'm almost as enthusiastic about packing sharpeners as knives:D I'll usually have 1-2 Eze-Lap Diamond stones (1x3 or 1x4) in my pack, and one in my pocket. I don't think I ever used one in the field:p, but just in case...
The fellow who owns Black JackKnives and most if not all of his knives are convexed edge recommends stroopping on cardboard to refinish an edge.
I have carried a number of field sharpeners at different times, from a basic small pocket stone to an altoids tin sharpener, and all work fine. It's really all about technique.
Here is my current field sharpener. It is a 1200 grit DMT credit card, with a piece of loaded leather glued to the back.
But I believe your original post is phrased to ask about sharpeners that you might find in the woods, in case you are not carrying anything. A flattish, smooth stone found in a river or stream will probably be best, just use light pressure and don' focus on angles as much as making sure you are hitting the edge.
I have a KSF field hone colored with compound, with 1000, 1500, and 2000 grit wrapped around it stored in a small ziplock bag. Easy to keep things screaming sharp, light, small, and I haven't had to use lower than 2000 grit in the field yet.
Ron Hood also recommended the belt for stropping--he just rubbed ordinary dirt into the belt as a "compound." He also recommended using the edge of another knife as a sharpening steel to dress both edges at the same time.
I've started using this one...
This keeps everything in one place and it is easy enough to take anywhere.
