- Apr 12, 2009
The only area where I've noticed the AlumOx not performing well in s30v (or D2 for that matter) was in a stropping compound, and that is still pretty subjective - it did polish up the bevel nicely but there was a difference in quality of the cut compared to the SiC. The Norton India stone is one tough cookie.
There's a similar difference in the cut, when comparing AlOx/SiC to diamond, at grit levels below about ~3µ (i.e. DMT EEF and finer). I've noticed the biggest advantages of diamond in polishing stages at that grit and lower, if taken that far; especially with stropping, using 3/1µ pastes. If finishing to a grit level coarser than 3µ, using SiC or AlOx or diamond, there's not as much of a difference (that I can see) in the character of the sharpened edge. That's all perfectly in-line with the stated average size of the carbides in CPM-S30V, which is 2-4µ. At 3µ and lower, the size of the carbides will become an obstacle, if trying to abrade or shape them individually with softer abrasives.
I've been spending time lately, fine-tuning and polishing the edges on two of my S30V blades (CR Sebenza and a Kershaw Leek), using the 3µ and lower diamond grits (EEF DMT -> 3µ paste -> 1µ paste). With the thinly-profiled Leek's blade in particular, it's cutting as well as my Schrade 8OT in 1095, when polished. I'd previously never seen that in S30V, and had started to assume it wasn't possible. It's come much, much more easily, after I started using the finer diamond grits to get it and keep it there. Was never able to even approach that before, when I was attempting to use finer grits of SiC wet/dry (up to 2000 grit) and/or AlOx stropping compounds. Polished OK, but the edge apex was never nearly as crisp at the highest polish.
David
