What do you think about going from the WE130 to the Generation 3 Pro?I'm very happy with my Wicked Edge WE130. Even if I were a billionaire, I would still have it. Plus, with the WE130 you can grind asymmetrical bevels if you choose to do so.
Excellent advise. That is the sort of information and advise should be taught to anyone starting out on the sharpening road. The first stone is the most important, rush that and you may as well not even start. Have a good weekend.It's not difficult, but it is time consuming. It can take 3-4 hrs. for a really good result. Most of that time will be spent on the coarsest stone, making sure you get a full burr on both sides of the blade before moving on.
If money is no problem, the Nowi Pro is the way to go:I read a lot of what people had to say and I seem to see KME and Wicked Edge as the top two. What I would like to know that if money is not an issue, what would you use to sharpen any knife, even if it is some ridiculous $10 thousand dollar machine. I have mostly M390 blades but I have some 20Cv, S45vn, NitroV just to name a few. I have some knives that are $100 all the way up to $1,600. I really like the mirror edges I have seen on the higher end knifes. What are the professional sharpeners using? I have done some cheap knives by hand, however I do not trust myself on the higher end blades and would be considered a novice as sharpening goes. I do like the control and taking as little as possible off a blade.
docs.google.com
www.bladeforums.com
Do you know when the WE 130 was first released, been watching some Youtube videos on them, i did not realize that they had been around for so long.I'm very happy with my Wicked Edge WE130. Even if I were a billionaire, I would still have it. Plus, with the WE130 you can grind asymmetrical bevels if you choose to do so.
Do you know when the WE 130 was first released, been watching some Youtube videos on them, i did not realize that they had been around for so long.![]()
https://katocut.com/en/produkte/messerschaerfer/nowi-pro/
You can adjust the grinding angle to what you need it to be.
Only with systems like it, the angle will stay constant over the whole edge, even on knives with a curve to the tip.
Here you can find a document about the problem with the changing angle over the lenght of the edge:
Geometry and Kinematics of Guided-Rod Sharpeners – Wicked Edge Precision Knife Sharpener
knife.wickededgeusa.com
Geometry and Sharpening (DRAFT 1.0beta5).zip
docs.google.com
You can use every type of bench stone from diamond to Japanese natural stones.
You can find videos about the system here:
Sharpening Systems- What is best.
What's wrong with being careful? Like my Ken Onion a lot. Nothing wrong with being careful. I'll admit that I'm a little impatient and like to run the blade through quickly. It's not as mindless as the Wicked Edge where you don't have to worry about holding the blade straight. I will say that...www.bladeforums.com
Sometimes the angle will be constant with fixed rod system, but that's a function of the blade grind. If the blade is ground with a near-constant thickness behind the edge, then a fixed angle system will produce a bevel of consistent width. OTOH, if the blade is considerably thicker behind the edge towards the tip (as many blades are), the bevel angle will fatten up towards the tip.
It doesn't matter how long the blade is. I've seen plenty of <4" blades that got quite thick toward the tip. My Sebenza 31 is a good example.That may be so with really long knives and swords. But you can string 2 or 3 Wicked Edge vises inline for them. There are people that do that.
No, I didn't clamp it wrong. If you maintain a *fixed* angle, and the blade thickness behind the edge changes, the width of the bevel must change in order to apex the full edge. In the case of my particular Sebenza, the blade is about .017" bte about 1/3 of the way up from the heel, and about .030" bte towards the tip, so it's impossible to maintain an even bevel on a fixed angle system.You must have had it clamped in the vise wrong. Do you have a photo of it clamped in the vise?
