- Dec 31, 2005
Interesting thread and a lot of good advice .... personally after years of using all sorts of sharpening methods .... I wish I had invested in a cheap belt sander and some good belts a long time ago. There is no better method once proficient than using a belt sander for re-profiling an edge .... knives that come sharp and to the right angles can be sorted and kept on top of with stones and strops .... to me they are the tools for keeping a sharp edge sharp .... and are excellent for in the field use .... but if you need to sort out a poor grind or want to change the angle on an edge to something better suited for your needs .... a belt sander makes it all "tolerable" when it comes to time .... and when it comes to frustration over the money you have spent too ....
Using cheap blades can be ironic and sometimes frustrating though when wanting to practise .... I ordered some cheap Mora's thinking I would have good steel to practise on .... they came "razor" sharp .... LOL .... and cost next to nothing compared to any of my Busse's .... or other knives for that matter.
Machete's though are often soft steel .... that means they have difficulty taking a fine edge on the speed of a sander and seem to always roll one way or the other .... but they do give you something to practise at and nearly always need a proper edge applying .... they also show you what a rolled edge is .... that is MUCH more than a Burr .... and you won't fix that with a strop easily .... unless time and patience are given in large quantities .... and from reading the responses above it sounds like some have rolled edges and not burr's to sort out ....
The best thing to practise on using the belts in the higher grit area are old tool files .... they are hardened metal and will take a great edge .... they will show you all you need to know by letting you create the edge from scratch .... and remember to use a face mask and appron because the dust and sparks will surely fly .... but once you do an edge from scratch you will have no problem understanding what it takes to tweak an edge already formed .... as going up through the grits should give you a good idea on the file as to what you need for a touch up job on a knife ....
If you are into Busse's and performance in using a knife .... a belt sander will save you days of toil on stones or mousepad systems ....
The stones and strops just let you keep a knife in tip top condition ....
