I love my small Sebenza but I hate sharpening the thing. I profiled to 20 degrees on the Sharpmaker which took forever due to the lack of an aggressive cutter on the 204 and due to the high Rc of the Sebby. When that was done I went about polishing up the edge on a belt with some Flitz on it to give the edges that mirror look when it was NIB. When I stropped the Sebby I must have overdone it and rounded over the edge because it would not shave hair easily and it struggled to cut through paper. So off again to the Sharpmaker. I used the fine rods for about 15 strokes per side and the knife showed no improvement. So I marked the edge with a permanent marker it to my surprise, I still had a little black line at the edge, meaning I was not raising a burr. But how could this be?. When I originally reprofiled on the 204, I used the marker and I'm sure I raised a burr. So in go the medium rods. After about 50 strokes I raise the burr and work up to the fine rod and then finally its time to strop. Before stropping, entire edge is popping hair. After I strop on untreated leather belt, the edge up to and including the belly is scary hair poppin sharp but the quarter inch to the tip will barely cut hair. So I go back to the fine rods on the sharpmaker and now I can't raise the burr on the edge with the fine rods. I guess the med rods are back up after work. What the **** is my problem. I didn't overstrop this last time and the rest of the edge turned out fine after stropping. So why is the tip and screwed up? Anybody else having these problems or am I an original. BTW, I sharpen all my knives this way and they all turn out wicked sharp. Am I missing something with the BG-42? Is it possible that I have a Sebby with defective heat treat because it seems impossible with the impeccable quality of CR Knives. Comments welcome and appreciated.
