I'm going to stick my neck way out and say something very controversial here:
Not directed towards anyone in particular:
If you sharpen dry and claim it's just as good as sharpening wet but have never actually experimented with your process and truly validated your claim, what you have is an unsubstantiated opinion and you don't really know.
I have no problem with people sharpening dry. Most folks do it that way. I don't care, I have no dog in that fight. What bugs me is when people who sharpen dry say "I do it this way, it works fine, no customer has ever sent a knife back, there is no reason to sharpen wet it's just as good" when they don't actually really know.
Test it for yourself. It's extremely simple. Do these two simple things:
1: do a side by side test and prove it to yourself. You need two identical work pieces (same steel, same HT etc and same controlled edge angle) and do one wet and one dry, then cut identical amounts of the same materials and view the edge under bright light and magnification and see how well the dry ground edge holds up compared to the wet.
2: test to see how far out of whack your sharpening process needs to get to actually color an edge. A somewhat dull belt, a little too much pressure, move a little too slow. How bad do you need to screw up to clearly ruin an edge? You all know that most steels we work with will not run color after a brief trip to high temp unless you really burn it. So generally speaking if you can see it, you're probably way over the line. It's easy to do.
Most modern steels get pretty hot when you sharpen them because the alloy content slows heat conduction and high carbide steels take more effort to abrade. Couple that with the thinner edges of high performance custom knives and you have the real possibility of the occasional burnt spot without ever knowing it.
Again, I'm not saying there is anything wrong with folks sharpening dry. I think it's an acceptable way to do a reasonable job if you're careful. But for those same folks to claim there is no difference when they themselves have not actually tested it, and then disregard the claims of those who have, is not good.
I have tested it for myself and formed my own opinions based upon the materials and geometry I'm working with and what I consider "acceptable" and have opted for a wet setup for sharpening. It's not as messy as you might think.
