The angle is only part of it. I've used Shave Secret as a pre-shave followed by shaving cream. I have a goatee (or van Dyke, or whichever it's truly called) and have no problem having a fully lathered face. I just take my finger and wipe the lather off of my beard at the edge. It works very well. A good shave soap or cream is quite important, I discovered.FWIW, I finally ran out of generic cartridges for my Atra, so started with my DE today. I used a Feather razor, Dorco blade, and Shave Secret and water (I shave around a beard--need to see the edges).
No irritation to speak of, but not the closest shave I've ever had, either. I must be messing up the angle somehow. Far less irritating than a brand-new cartridge shave regardless. Still have a lot of blades from the sampler to try, so hopefully I'll improve. There's always the Futur or a slant bar if the Feather doesn't pan out.
The Feather isn't the best of razors. It's doable, but there are much better out there. Is it a TTO or a 2/3-piece razor? I would opt for a vintage Gillette before a Feather. I have 5 SuperSpeeds and just don't need them all. I've kept one and am unloading the rest. If you want, I will send you one of my Gillette SuperSpeeds. The finish on the doors isn't the best and probably won't sell on eBay because it isn't near-perfect, but it shaves very well.
TTO = Twist To Open (the butterfly doors). The SuperSpeed razor I'll send you is also a TTO, though not as nice as this one.Sir, thanks for your generosity. I've sent an e-mail. The Feather's a 1-piece with butterfly doors--not hip to the lingo so I assume it's a TTO. The packaging said Feather but it looks similar to this one except with black safety bars.
That's what I thought, too, but never really put a lot of thought into it. Well, I got to thinking today (that's a dangerous thing) and searching:FWIW I think the goatee is the chin cover + mustache, and the Van Dyke is the chin cover only. Thanks again!
I noticed that my SuperSpeed needs more than just Shave Secret to glide smoothly. If it doesn't glide smoothly, the shaving will be rough. Definitely use shaving soap or cream with the SS. As for blades, I found that Bic blades worked well in that one (I sent you the W-1 date code, right?)I used my new Superspeed razor (thanks again Loonybin!), a new Dorco blade, and Shave Secret and water.
<snip>
I think I was muscling the Superspeed; the Feather was roughly the same length and weight of the Atra, so 25+ years of reflex kicked in. Either that or I need to start moving through the other blades in the sampler.
loonybin said:I noticed that my SuperSpeed needs more than just Shave Secret to glide smoothly. If it doesn't glide smoothly, the shaving will be rough. Definitely use shaving soap or cream with the SS. As for blades, I found that Bic blades worked well in that one (I sent you the W-1 date code, right?)
COME ON GUYS! Close to 200 replies and only ELEVEN pictures?
Am still having trouble above the top of the beard. I was able to shave effectively along the line with the Atra but neither the Feather nor the Superspeed will do it. I guess with only 1 blade I need to stick to N-S lines. The neck was more effectively shaved but less comfortable. I think I was muscling the Superspeed; the Feather was roughly the same length and weight of the Atra, so 25+ years of reflex kicked in. Either that or I need to start moving through the other blades in the sampler.
From what I'm reading here lately, I'm beginning to think the Shark and Lord blades I got should go in the trash without investigation, and I should focus on Dorco, Merkur, Feather, and Bic.
No pix from me as I don't own a camera
The Old Spice Shaving mug looks tidy and useful. What's the nearly finished cream in the green tube though?
