- Nov 30, 2001
Good thread!
There are a lot more sheath makers on BF than I ever imagined.
As far as grooving, I do groove both sides of my stitching, tried it without and didnt like the look at all. The only time I've had issues is on very light leather, up to 5 ounce, the heavier the leather I use the more I can bear down on the stitching.
No rivets on the inside on my work if at all possible, I've gotten knives in for fitting where the old sheath had a riveted loop, it almost always marks either the blade or the handle. In a lot of these cases, the rivet was covered with a little patch of leather that nearly always comes off through abrasion. Lining of some sort is much preferable, but not always feasible, easier to simply stitch it on.
More often than not I drill stitching holes, I am a full time maker so its a great time saver.
On the pouch sheath above, its not level so you need to back up the welt area or hang the bent part of the sheath off your backing material. You want the edge of your sheath to be as flat as possible, 90 degrees on the awl as well. Sit that pouch sheath on a table and look at it straight on from the side and see how off you are from 90 degrees on the edge. Same goes for sanding the edges, pouches can be a pain to sand square, especially on a powered sander.
Hope this helps a little jmflem.
