- Aug 8, 2005
awesomely informative thread....thanx a lot Chuddy Bear! :thumbup:
Chuddy... your edges do it for me in a most disturbing way...![]()
Another question if I may.... when I made my very first sheath, my edges after sanding and then using edging gum to seal the edge, started to show gaps in them down the side of the sheath...
The gaps will happen over time, leather is relatively soft and it does stretch over time.
Any suggestions?? I think it is probably partly that I needed to stitch closer to the edge, and partly that the contact cement didn't go right to the edges... sound about right??
You need to think of contact cement as just a temporary substance that is only meant to hold your sheath together until you can sand and stitch it. Do not count on the glue to actually hold anything together once it is stitched.
Did you harden the leather at all?
I have also ordered a small 118ml bottle of black dye, so that I can re-dye my edges (the shoulder leather I got was pre-dyed, so after cutting it, it needs to be re-coloured). Do you water the dye down?? Or will 118ml last only 1 or 2 sheaths?
It depends on the size of the sheath. I havent tried any water in my dye but I do use 70% rubbing alcohol. The dyes straight out of the bottle with the exception of black, will almost always never come out right if put on with a wool dauber, unless you soak the leather in water first.
For me getting the dye job right has been the hardest and most frustrating part of sheath making. I have spent a good deal of time experimenting with dyes to get them to come out right. I havent found any good tutorials on how to do it right, must be some kind of leather worker secret or something.![]()
Cheers bud
Alex
Thanks for your reply Chuddy
Firstly, the leather came pre-dyed, so whether this has any 'hardening' I am not sure... I haven't personally used anything to make it harder... I personally believe that my stitches were a bit too far in, and the gluing wasn't accurate enough... practice I guess...
The rubbing alcohol bit... do you mean you use a 70% mix, i.e. 70 alcohol and 30 dye, or is this rubbing alcohol actually called, 70% rubbing alcohol?
Lastly, what types of thread are you using, or which do you prefer?? I have just bought some huge 1mm thick pre-waxed cord, which is super strong, and looks like it's a great choice, but I am unsure on the size of drill bit.. I've been using a 1mm drill bit when stitching with normal thread, but obviously saddle stitching a 1mm thread in a 1mm hole, will mean an overlap of thread, equaling 2mm... I guess just move up one size, but if you can recommend a bit size, that'd be fantastic...
Again, many thanks for all your help here... I aim to get good at this stuff... and I find it immensely good fun.. as I'm sure you do! :thumbup:
Alex
