- Mar 14, 2009
No offense, P, but those are some of the most hideous sheaths I've ever seen in my life :barf:
thank you, Dwayne did a heck of a job on em.
Heres another by Rainwalker I found today, and its sweet too!
http://i297.photobucket.com/albums/mm221/knifehunter_album/Grails016.jpg
http://i297.photobucket.com/albums/mm221/knifehunter_album/Grails020.jpg
Yeah, I guess I could see myself getting sick of those pretty quick.. Ijust thought they were cool looking. I don't have any prior knowledge of Jay Fisher.
I still want Carbon Fiber...
Too bad no one can make a carbon fiber sheath!!
http://www.jayfisher.com/
if you like stone handles, file embellished spines on every surface, 440c, and high polished everything, he's your man. if you like that sort of thing he has the largest collection of designs out there in that format. I dissagree with many of his comments regarding hard use and his choice of materials, but 440c is a classic steel that does well when heat treated properly.
If I liked that sort of thing, I wouldn't be here.
I just wanted an over the top sheath.![]()
http://www.bladeforums.com/forums/showthread.php?t=258922&highlight=kevlar
lol, I was wrong. it was andrew lynch. 2 layers of .090" kydex sandwiching a layer of kevlar. wild stuff.
no offense, p, but those are some of the most hideous sheaths i've ever seen in my life :barf:
What about Carbon Fiber Concealex?
It just doesn't look the same..
Is it really that much of a PITA to mold wet CF around a taped up blade?
I'm ignorant, but is it?
My knowledge on actual CF is nill, so not sure what would be involved. If it can be formed like that, then I imagine it's doable. Going outside the knife world and getting one made by a shop that makes other CF things may be an option.![]()
Well, it is not like kydex, which is molded with heat.
It is more like Fiberglass. It is just a cloth, which you mix with resin, and it hardens.
Not much too it.. I guess it is hard to make it look good...
Carbon fiber/epoxy composites are generally cured under heat and pressure. But since a knife sheath does not need the same ultimate properties, you might be able to devise a wet molding process combined with a room temperature cure resin system.
(re French's Mustard patina patterns) you can do all kinds of sweet patterns. The longer you let it sit, the deeper the etch. If you do a bunch of repeated layers you can get a look very similar to pattern welded damascus.
