For Sale: Shirogorov Neon NL NIB. This is the newer blade shape as the Neon Zero. Full Titanium handles with a darkened-stonewash with green linen Micarta inlays that aren’t flush but raised for traction and grip, of course this model is so intricately finished from the three small titanium pins that are near the butt-end and not only do the look cool, they act as a guard so when the blade is in the closed position you cannot get poked by the sharp tip. Every corner and curve is chamfered and little design cues are filled in this little masterpiece of a production knife (pictures don’t do it justice but capture the beauty of the newer designed Neon NL. The NL just stands for lite because the model only has (1) mirror polished barrel spacer with an open construction making it extremely light (relief machining inside the ti handles. The stainless steel lock insert is masterfully hand fit to where it looks so hidden and finished it’s crazy this is a production piece but as knife nuts know what you get from the Shirogorov’s shop. The expertly heat-treated, Elmax steel is again, beautifully flat ground & given some subtle jimping that is right we’re your thumb would rest. The vape blasting finish is seamless and ELMAX is the only marking on the blade. The flipper tab is unobtrusive and also has some smooth textured jimping as you would expect rockets the blade out on Shirogorov’s MRBS (Multi Row Bearing System) wich is machined inside the frame near the top of the spine as expected. The ss insert also acts as an after travel stop for the locking cut and also houses the ceramic detent. The Neon NL is a drop shut piece and it is what other makers attempt to strive for and continually compared as it’s the best action on such a light blade though it locks up like a bank vault and disengages smoother than butta.
$560 Priority Shipped & fully Insured via USPS. ***Will only accept PayPal, friends & family option. Once payment is received & verified the item will ship either that day or the very next if USPS is closed. I will also provide you with a picture of the receipt & tracking # number once it’s out of my hands.***
I’ll end up buying another or another model because of the sheer beauty & quality you get out this particular knife and besides I own another.
