Having a spear is a very good option for primitive hunting.
I have a spearhead I made myself from a bit of stainless pipe and an old bayonet blade. But after making this I bought a Cold Steel Bushman and it makes a terriffic spear.
Instead of using a nail through the hole in the handle to hold the knife in place on the shaft, I use a strong bit of synthetic cord. For a start I made a prusik loop around the handle which was tied to a cord fastened to the spear shaft. Eventually I drilled a hole nearer the front of the handle and I have a permanent bit of strong cord tied through this... and when I want to fix the knife to the pole I have everything ready to do the job quickly.
I had to use a specially sharpened carbide tipped drill to bore a hole through the hard steel handle... a normal HSS drill couldn't handle it.
My full-size Bushman was a bit big for me, so I cut a bit off the handle and a bit off the blade and reshaped it. It now sits right down inside the factory sheath and I am much less likely to lose it compared to when it was full-size.
If I were to buy another Bushman, I would most likely get the shorter Mini Bushman.
Using my Bushman spear, I killed a boar which I caught in a primitive rope snare. Heres a picture.... unfortunately the pig didn't have its head on when this picture was taken. I cut it off before I carried the rest of the animal down the hill.
http://home.clear.net.nz/pages/coote/pig and spear.jpg
I will be away from the computer for a couple of weeks.... but I will be interested to see what else you guys have written when I get back.
From my experiences so far, I can recommend the Bushman.
Best wishes.... Stephen Coote, Nelson, New Zealand.
