Bigg(ish) Douk-Douks. Slim, light, easy to sharpen but poor edge retention (consider carrying a pocket steel), very heavy backspring.
Small(ish) Victorinox daypacker. Similar to Douk Douk, but shorter (2.5" blade) and very non-threatening.
thought Douk Douks were just friction folders(no backspring)? I've never seen one in person though.
Good to know, but now I've got even one more knife to try and choose from.No Douk Douks have a super strong backspring, one of my all time favorite carry knives. A small Douk would fit your criteria and they get stupid sharp very easily.
The coping blade on the kutmaster gives a lot of mechanical advantage to the point, especially good in a non-locking slip joint since pressure on the blade point helps keep the knife open. Made sense a hundred years ago, still works today. A lot of knife in a small unassuming package.
Don't get me wrong, you can have all the lockbacks you want but it can be an issue if you're ever stopped. You're not likely to ever be stopped but it is possible.
NYC's laws state the knife must be concealed. It also has to have a blade less than 4". "Gravity knives", lockbacks, even autos are technically legal to carry with a valid hunting/fishing license when you are going to/coming from/ or doing said activity. A slipjoint with a max ~3" blade is safest to carry the rest of the time.
Also, technically a <4" fixed blade is legal but you do run into the possibility of it still being considered a "dangerous weapon" depending on the officer.
With regards to the Opinel, it's probably best asked in the Knife Laws section and there they'll probably say its safest to ask a lawyer but they should be ok, even if they lock. I don't have an Opinel but I understand that they only lock open by turning the ring? If so, that'll probably be considered a separate action from opening the knife and so not a gravity knife (there is case law regarding a balisong not being a gravity knife because a separate motion is required to move a latch to lock the knife open. Balisongs still fall in the "other dangerous knife" category though.)
