- Oct 17, 2010
Actually, the sewing machine motor is almost definitely a 1/2-3/4 hp clutch motor, or a 3/4-1hp servo motor. The clutch motors don't really offer fine control, and I don't they've got much torque. I can't comment too much on the servo motors, since my industrial sewing machines all have clutch motors, but I have used the servos a bit, and the control range is much finer, but I still doubt the power would be suitable.
It's almost surely a DC motor. Model trains, slot cars, and lots of other equipment run on DC for variable speed.....
Medicevans... If you buy the single phase motor, then you will need step pulley's like on a KMG. Go to Beaumonts site and price out the pulleys, pillow blocks etc, and you'll see you're not saving much vs getting a 3ph motor with a VFD.
Maybe look at the Vacon or TECO VFD drives to go with a 3Ph motor.... The "standard" is a KBAC27D, but some people use other VFD's with success....
Sam's illustration above helps....
This is what I did.... I bought a KBAC27D VFD, a 3ph 1.5hp motor for my GIB. The cost for the VFD was $400ish. But here's the pay off.
I just bought another 3ph motor off eBay for my disc grinder, now I have variable speed to two machines for the cost of a single VFD and some switches. I plan on adding one more disc down the road to run off the same VFD.
If you did by that motor, you can add a 6" drive wheel and use as is. But it'll be single speed.....
Also, I assume you are looking at 56C motor frames, with TENV or TEFC housing?
