Richard338
- May 3, 2005
Yes, I will certainly switch to a more sensible backing. I'm going to make three of the tsuba now to take a break from polishing.
Well, I have struggled a couple days with bringing out the hamon.
I started with wiping on fairly concentrated FC and the reaction seemed too fast and aggressive.
I repolished it and started 15 minute baths in white vinegar after reading Willie71 in "The Hamon Thread".
This was working, and while polishing between each soak, the piece was taking on a beautiful very slight gray appearance, but glossy.
It seemed that the vinegar was not etching as well after the first couple soaks, so I added a small fraction of my FC solution.
This was working well and was still controlled.
I thought I was getting more efficient with the polishing. I wrapped an EDM stone in the 3M paper and it was working well until a SET BACK!
The stone made its way a tiny bit through the cloth. I didn't hear or see anything different, but close inspection shows some very light scratches.
The first image is direct sunlight and exaggerates the scratches. The second one is indoors and shows the hamon as darker.
In any case, I'm going to drop back to 600 (hopefully not lower) grit and redo the polish until the scratches are gone.
One option based on a suggestion from Stacy is at the end, to try to achieve a different, brushed look on the part indicated in blue (like Stacy's first image above).
I'm not sure about that yet, but I'm going back to sanding and cycles of bringing out the hamon (hopefully without scratching it this time)
Some tedious progress...
Those look great! I'm looking forward to seeing them with the accents in place.
Some more progress at last. Actually the 4 pieces that will have wrapped handles are in the final stages, the handle cores and parts are all shaped and fitted. I got some great menuki and soon I'll do all the rayskin wraps.
In the mean time I decided to finish the aikuchi style one which has the smaller of the two san mai blades.
I discovered that the block of African Blackwood at 15/16" square was too small to use if I split it down the middle.
Using my new disc grinder set to 45 degrees I knocked off opposing corners and sawed it along the diagonal.
Pretty tedious, but this allowed me to just fit my handle patterns.
I used my new chisel set to carve out the saya part and got a good snug fit to the habaki.
The wood took an amazing polish at 2000 grit and feels like glass. The joints are really seamless.
I'm very happy with how this first one turned out.
Only 4 more to go...
Thanks, yes, it looks really slick and will definitely spend a few nights on the night stand.Very well done. I like Aikuchi and guardless swords. It give you a chance to make some really sleek looking weapons.
