- Nov 16, 2016
What are your thoughts on this tang? It’s a Lionsteel M5 in 3v. I was soooo excited to get it, and it feels absolutely great in the hand. From nearly all perspectives it’s a perfect bushcraft/survival/edc fixed blade…until you take off the scales. Would you hesitate to put this knife through its paces? I’m not sure if I should forget about the tang and not worry about it, or if I should look for something with more meat in the handle.
Back on topic. As mentioned on the other forum, this would not bother me at all. As far as skeletonizing goes, they did better than many. They left the area around the front pin hold pretty thick, and around the ricasso.
That lionsteel is 0.18" thick and likely at least that in width at the skeletonized areas. Even just a 1.5-2? bar at 0.18"x0.18" is going to be pretty hard to bend, and 3V is pretty hard stuff. If it breaks, like the gentleman mentioned about the BK2, it's not because the design, it's because something was wrong in the steel itself and it performed wrong.
With a blade of only 4.5" long, it's going to be really hard to get enough leverage to even bend that with lateral loading (prying, uses is a step, etc). And CPM-3V is a steel that tends to do really well against abuse, a lot of abuse. I'm sure lionsteel doesn't heat treat as well as Carothers, but look at some of the stuff Mr. Carothers does the 3V. You'll probably see more edge damage on the lionsteel, but the edge is many times thinner than that skeletonized tang. Even a "standard" heat treat on 3V is very durable stuff, and lionsteel tends to do a really good job radiusing lines so you shouldn't have many stress risers from that.
What I would still encourage you to do is test YOUR knife and see what it can handle. Once you feel comfortable with what it can do, you'll feel more comfort in your mystical survival scenario. You'll also know more about how the knife works, handles, and cuts.
Seriously, just enjoy the knife. I've been a fan of all of the lionsteel fixed blades I've tried. Their edges are thicker than I prefer, especially on their folders, but for harder use fixed blades it's tolerable and that's something that's not too hard to correct on the aggressive bench stones.
If you get to testing, please share pics and update us here and the other forums you've asked this question on.
