- Nov 22, 2009
If we had folders with those steels at a thickness of 1mm and FFG, how fragile would these blades be?
I love this thread, man!
I can only give you the answer that applies to MY uses. I find that the overall blade thickness is less important than edge bevel, grind, and polish.
There are limits to everything, but in my use, 3 mm FFG is a good enough strength point for ZDP or VG-10, thinner than 2 mm and bending and fracturing would be more prevalent. BLADE grind angles of a certain thickness get so thick in some cases that even technique can not adequately reduce the binding between the blade shoulders and the media.
Anyone who wishes to understand this technique I speak of, simply grab the thickest piece of cardboard you can find (hopefully you can find some heavy duty stuff that looks like 2 or more normal pieces of cardboard laminated together), now make a 10 inch long (or so) cut with the knife held perpendicular to the cardboard. Now make a cut with the knife cutting at a 45 degree angle to the plane (when you are done you will have 2 sheets of cardboard that have an edge resembling a chisel). This technique will "open up" the media during the cut and reduce a lot of binding on the sides of a thicker blade. Yes, you are technically cutting a greater thickness of material by leaning the knife (particularly if the media is not porous like cardboard), but it still reduces the binding enough to demonstrate how much cut resistance is attributable to this factor.
Perhaps a lot of you guys know this, but it will save you a lot of sweat at the end of the day if you use your cutters a lot.
