- Jun 27, 2009
AW, when you get ready to heat treat let me know and you can stop in and use my Parks 50 and forge.
This thread started oout slow, but has seemed to pick up steam.
Anyways. I ordered my Evenheat KF18 today and should be here in the next couple weeks, so I will be using that to get to temp. I'll look into McMaster and the fast quench. I just don't want to get into anything expensive that will be used once and put away. Someone mentioned used diesel oil, which is funny, because I have about 30 gallons sitting along the perimeter of my garage, due to having a 6.0 Powerstroke for 5 years (now it's a 6.7 powestroke).
I do not intend to use 10** steel in the future. I am concerned about the fumes and smoke, storing the oil, the actual quenching process. My wife has a nose like a bloodhound, and swears that anything that doesn't smell like roses gives her a headache, plus a Dachshund that will cower in a corner when I cook on the stove, I do not want to expose them to the fumes and potential smoke. By the way, this is all in my attached garage. I have little room to spare, and storing a container full of oil isn't something I have room for (or want to work around). If I can get away with a gallon of quench, and doing it to get the upcoming blades done, all the better.
Ohio guys. Grinder is set up, but needs to be moved, as the bench is a little high, and I am not comfortable grinding at that level. HT kiln will be here in a couple weeks. If I get really ambitious this weekend, I might get the head of my Bridgeport back on and get it operational (and maybe figure out why the Y axis will move towards the column but will not come back). Maybe we can get together somewhere, talk, grind, HT or whatever. Maybe you can show me how to run these things too.
Aaron
Aaron
Aaron-
I wouldn't try to talk you into oil hardening steels, but after reading your last post I gotta ask- You do realize that almost everything in knifemaking is going to cause very bad dust and stink right?
You may want to try Ford Type F auto transmission fluid. This was recommended to me by a well known maker. Available at WalMart @ approx. $5/Quart. I'm sure others will offer opinions on whether or not this is advisable.
