- Jul 22, 2013
Can you not grind them straight? How warped are they?
Where did you send them?
Not what I meant. You can grind out the warp when grinding the bevels.I don't think I can. When I put them on the surface grinder and engage the magnets, it pulls them flat so I don't think that will grind out my warp.
Tip:
You need to shim under the warp when you put it on the surface grinder. A quick and simple way to do that perfectly is to put a coat of 5 minute epoxy on the concave side. Let it cure and flatten on a surface plate with 100 grit paper. Place on the magnetic chuck epoxy side down and grind the convex side flat. Flip over and grind the epoxy side flat ... done.
Thanks again for allowing us to watch how you are progressing on this project. I didn"t realize how much went into one of these.
Awesome looking blade and the carbidizing of the lock bar face is surely the way to go.
