Friendly reminder, don't choke up on that otf, just saying, your thumb will be mad at you![]()
So I have managed to get by with just these two knives/tools since I started this challenge. Even going on a hike, i resisted the urge to carry something larger (because I knew I really wouldn't need it). The Hera does about 90% of the cutting chores. The Charge usually is used when I am either using the tool for something and need a blade to strip a wire or something or I want to use the serrated blade for fibrous material. I think the Hera gets the nod so often because I have really grown to appreciate the bayonet grind on such a small knife. It's counterintuitive, but it actually works better on a smaller knife. The jimping gives me a place to choke up on the blade, obviously. Also, I have kept the "false" edge (though it is fully sharpened) a bit toothier and robust. The primary edge is polished smooth. Having that little hard use edge saves the "good" edge for cutting finer things. Being so close to my hand makes for some really precise cuts.
I forgot about what I carry in my boot... yep. Under 3"![]()
I don't own an otf, but I always thought you were suppose to retract it by pushing it closed with the adjacent palm, wowzerz, learned that one just in timeThanks, mom. I'll try to be careful, but it's almost like the jimping on the spine was designed to be used exactly that way
I will say that retracting the blade with my thumb in that position may be a bad idea.
That knife is so small, the camera can't even pick it up, fascinating!
The Mini Nonexistent from Microscopic KnivesMini micro
