The objective is to find out how to turn pluckable foam from pelican type cases into a more solid foam piece once you have shape you need created.
Winner gets an attaboy![]()
That's sounds dumb. Let's not do that.
Anyone figured out a way to turn that pluckable foam into a more solid piece once you get it shaped?
Stuff makes it easy to customize cases, but then if your not careful pieces get loose or come off and then it just doesnt look or fit as good....
Im thinking maybe use some spray adhesive and spray the entire bottom side, that or if it gets sticky when heated maybe i could use a heat gun and melt it just enough to make it stick back to itself... Both come with risk of ruining the foam though.
Man. They'll let just anyone start one of these.
well, it's definitely Monday........
Wood, that stuff is a good idea that just doesn't work. We had 4 large pelican cases that we stored our gps units in for transport and storage. The first 4 we had were cut from solid foam. The next 4 had that pluckable foam. We tried all kinds of ways to keep it together. But the foam is so porus it never provides enough surface area to maintain any kind of a stable bond. Constant removal of the items caused it to flex and break any kind of bond that may have existed. Pure shite. Buy a large piece of cushin foam an cut it yourself. Of course, you'll need to get a sharp knife.....
Doc
Also spelunked for the first time yesterday.
Hey guys/gals that are going to BLADE. Here's something just in case your interested.
http://www.bladeforums.com/forums/s...ck-T-M-Hunt-and-BLADE?p=14789955#post14789955
Also, should have my BK15 by some time this afternoon. :thumbup:
Oh hi.
Rock on with your bad self! Have fun and be safe.
