Yes, it seems you are quite confused.
It's common sense really. The older I get, the more i'm finding it's not so common and is possibly dying out with our forefathers.
Everything on this planet has a breaking point. Everything. When someone chooses to push something beyond it's inherent limits. It breaks.
Most often due to ignorance and lack of common sense. If you respect your tools, they will return the favor.
Our forefathers could make a simple slipjoint pocketknife last a lifetime of hard honest proper usage, yet many here can't seem to keep a spring in a knife for more that a month or two.
Something is wrong here..... and it is neither the manufacturer nor the steel that is at fault.
What you are saying is that either the design of the spring is bad or something was wrong with the spring in question. Kershaw will have designed that spring to deflect a certain amount. IF it has been designed well and manufactured well, the stress induced in that spring from use will be less than the fatigue limit stress. Steel approaches a "fatigue limit" - if the stress is lower than the fatigue limit stress (assuming there are no pre-existing cracks greater than the critical size for the level of stress) then the part will NOT fail from fatigue EVER. It could also have been designed for certain number of cycles. Frequency has NOTHING to do with fatigue, but number of cycles does. There is not enough strain energy stored in that spring to heat it up at the frequency of a knife being flipped - I do not have the means to test this but I could attempt it analytically if someone would provide dimensions; the point is that the small amount of heat put in the spring will not raise its temperature anywhere near high enough to do anything to the steel.
SO - if the spring has failed prematurely - something was wrong with the spring. If the spring has been well designed, then there was a pre-existing crack. The spring would have failed at the same number of cycles no matter the frequency with which the OP cycled it.
No, what i'm saying is that designers/engineers design in parameters for "Normal Usage". Incessantly flipping your knife open and closed takes the spring beyond its original design parameters for "Normal Usage" due to repeated overuse which causes work hardening and eventual failure. Frequency of cycling along with number of cycles does indeed play a definite role in spring failure. It is neither the fault of manufacture or of the steel itself.....but the fault of the end user in the way that he uses/treats his knives.
You designed the cryo? The spring? No. You don't WHAT Kershaw designed the spring for for all we know they overbuilt it to withstand ten folds the stresses it would be subjected to or maybe to withstand only 50% of the stress subjected.
Right now you are trying to blame the end user when the evidence of a way premature failure says it was the spring. Kershaw themselves admitted that spring sometimes fail and given the fact the Cryo is a popular knife I am sure this is just one of those low probabilities.
My point stands: yet to explain anything.
Again, common sense, Luis.
Why would Kershaw design a spring to fail? Failure would potentially hurt sales.
I've made my points as clear as possible.
In Reality, the end user does and must bear some of the responsibility in how the knife is used.
Meh, ain't no squirting the milk back into the udder. What's done is done, but I'm sure Kershaw will make it right with the OP.
And yes, habitually flicking your knife will cause accelerated wear and tear. Same as with anything that is used often.
That's my two-cents...![]()
Common sense only gets you so far.
Business sense would be to overbuild the spring in case in case people decide to flick it. Thus help avoid a PR scandal, and minimize returns.
Really? What if the average failure is 1 in a 1000? Would it make sense to overbuild then? Do you know the numbers? I know I sure don't. I'm giving Kai the benefit of the doubt that they know their business. Feel free to share your good business nuggets...maybe they will listen....or maybe they won't.
You just supported my point. If you took the time to read the discussion. We don't know, won't know. What we do know is it's rare for them to fail and if they fail in a few weeks chances are it was a bad spring just as the KERSHAW REP SAID.
And this is why I don't buy assisted knives... Not dependable.
How many have you owned? How many have failed?
What we do know is it's rare for them to fail.
Here's how it happened. I was just sitting down, messing with the cryo as i usually do and then found myself flipping and closing it with my left hand and then *snap*
Mine did the same exact thing. Can't say I was surprised. I took the broken spring out and now it's manual.
Don't feel bad I have broke my Cryo twice. Contact Kershaw and they will take care of it. The only down side is because it is an off shore knife you will have to mail it in and they will mail you another one. No big deal.
Call or write Kershaw before sending it back. They may very well have torsion bars in stock, even for their imported products. I just got a replacement torsion bar for a Volt II from Kershaw (actually, they sent me two), and that is also made in China.
Same thing happened to mine not long after i got mine, snapped in the same exact spot too. Kershaw is good with their customer service and should help out pretty quick.
