So, you are stuck on a deserted island...
Since I Don't do fixed blades, I'm going to pick my Strider SNG Z-Wear and Custom SAK that has a saw and everything else I'd need.
Machete of your choosing, and a multitool.
There is a very good reason when people go to the jungle they take a machete and not a Busse and it doesnt always have to do with cost, they are simply more effective.
I mixed up and read the wrong comment on the first page that said something about the discussion being an arctic climate. If it's a jungle environment you're absolutely right, but if we were discussing a more northern climate then that same machete is much less useful and a heavier, shorter blade would serve much better. A longer and thinner khukuri might be a better compromise for either climate. What do you think?
In an arctic climate I would probably take a sharpened shovel and a multi tool.
Machete, large multi-tool and a set of golf clubs. I hate golf and being stuck on a desert island with nothing to do is probably the only way that I'll ever get into this game.
n2s
n2s
Great, you want to take up golf when you're stuck in one giant sand trap surrounded by a water hazard? You will be really pissed after you lose all the balls your first week!
I suggest tether-ball! ;)
A machete would still work but an axe would be better. A machete can be used to dig in snow and can also be used to make an igloo(if you know how.)
I'm with the other guys. I'd pick an Imacasa/Condor machete and that's really all you'd need. Maybe a back up machete would be prudent. To me a chopper knife doesn't even enter into my brain under either a tropic or an arctic scenario. Nor does the blade need to be stainless. Too many people think a knife will disintegrate if rust so much as touches it. It's just not the case IME.
I don't have a good machete, So I'd bring my Rodent 9. The second knife is a harder choice. If I had a survival tin it would be my leatherman super tool 300. No tin I would take my HEST 2.0 assault because the handle is loaded with useful stuff and I have a magslab in the sheath pocket.
My survival tin would make life much better either way. Tropical island preferred, I hate the cold!
Of those I own; My SAK Champ and Fallkniven F1-3G (sorry Swamp Rat Rodent 6- love you though!)
If I could go on a shopping spree; Any Spyderco with H1 Steel (for no corrosion worries) and a Busse 8"+ with .25+ stock
Fair enough. I keep hearing good things about the Condor machetes; I've never handled one and just have the cheap, basic machetes to base my experiences with the blade type on. May just have to pick one up. Is there an all-around best model you'd recommend?
Cold Steel super edge for my fixed blade, and I will pass on the folder and replace it with a good multi tool.
1. Fallkniven A-1
It is stainless enough, it is very strong, it is very sharp. Really a survival knife.
2. Sebenza 21, large. Only a few parts, absolutely reliable, easy to sharpen S35VN. Might be also Spy Military (my is in BG42 with CF handles).
Agreed. The only things a chopper knife can do better than an axe or machete are 1. to pry and 2. to limb trees. I don't see prying as the key to salvation, and if I did I'd want a nice BLUNT pry bar, because prying with a sharp edged thing should always be a last option. As for limbing, you're there to survive, not to tidy the place up.
Even if you have a Busse with the reach of a machete, swinging the damn thing will be too much effort when you are breaking trail - this isn't a matter of laziness but of sustainable work rate and water and food required. Machetes are light for a reason.
And I'd be even less comfortable with a big knife trying to chop deep into a dead tree for dry wood in a temperate/Arctic mishap. An axe is safer and more energy efficient and these things count.
I'd go for a Marbles machete (because its the brand I have used most recently) and a second as backup sounds a good idea. If I wasn't allowed one then I'd go for a SAK qith a saw and pliers. The axe combo would have an EKA H8 as the knife - very light, FFG, Scandinavian made and so thoroughly tested in cold weather.
A kukri is great at what it is designed for, but that is not digging deep into dead trees to get at scarce dry wood. Really: just think about the blade shape. As an agricultural tool it's mostly a limbing machine - although not as good a one as the billhooks that are said to be threatening its existence in Nepal.
Condor Golok, plus an Opinel 09, in Carbon for me. A Golok such as the condor can chop all out of proportion to its size, and is somewhat nimble enough to use as a fixed blade knife in a pinch, but the more delicate task could be tackled by the Opinel.
