Keeping in line with the question you asked:
One of the fine ingredients of cut and all around performance is fine grain.
From the first heat all forging thermal cycles are no hotter than 1625 f. Multiple thermal cycles and low temp forging (5160 and 52100) starting with large round bars allow a large degree of reduction by forging and sets the table for fine grain.
The finer the grain is, the lower the temperature at which it can grow.
Thus our desire to keep time above critical at a minimum.
Multiple quench cycles using a torch to heat the bottom third of the blade to just above critical can achieve a complete transformation to martensite with out long soak times, Rex has found no measurable retained austenite in the hardened portion of our blades so we know it works.
From an annealing temperature of 988 f. (3 heats) we know the tang is as tough and strong as it needs to be. The tang is never heated to critical temp during the hardening cycles, thus it remains strong and tough. Never have we had a tang break, we can drill them, cut them with a hack saw just like mild steel. This is important to us.
Thus preserving the fine grain we have been working for. Bill Moran taught me how to harden a blade with a torch, I practiced for months with a torch and mild steel developing my ability to harden with a torch.
The lab Rex works in just did an experiment using multiple quench to increase the toughness of some steel they were working with. It was very interesting, the cycles down through critical were timed,
first quench - 15 seconds
second quench - 7 seconds
third quench - 2 seconds.
Increase in strength, 20,000 psi.
Just another little experiment on multiple quench and a chance to watch a variable we had not been able to study before.
Heat control with a torch can be learned it just takes time, a student at present seminar just hardened his first 6 blades for the first time, he is learning fast.
Never apologise for asking questions.
