Hinderer XM-18 3.5" Highly Customized by Todd Begg,
Todd created a completely new thicker presentation side Ti handle in order to IKBS the blade. With the IKBS you will have little or no wear on the piviot due to the bearings. He did do work on the detent ,so the blade no longer opens up in your pocket but opens up a lot smoother and quicker since there is no longer plastic washers causing greater friction. The other thing is that he upgraded the hardware (custom screws) as well as re-profiled the scale to actually sit flush with the handle. If you compare the XM with your XM you will see that he also worked on some of the scale jimping so it all comes together. It also has a steel flame skull clip filler. THERE WILL BE NO MORE! TODD DID THREE OF THESE FOR HIS FRIENDS AND WILL NEVER DO ANOTHER. THIS THING IS RIDICULOUS HOW EASY AND FAST IT OPENS ON THE IKBS. AS FAR AS TRADES IM INTO STRIDER KNIVES.
