- Mar 22, 2006
Tarmix Very cool, Your getting my psyched up for my upcoming solo trip.. Looks like you had a blast...
America has reached 250 years, and I am grateful to be here, in the best country in the world. Thank every one of you who helps make this country a better place, those who have gone before and risked it all, and those who've paid the ultimate price to make the United States what we are today.
Great pictures, thanks for sharing!
I just noticed that tool you are using to carve the concave scoop of the spoon... I just don't know how do you call it. Anyway... I once read about the burn&scrape method to carve concave spots on wood. You just pick up a red hot coal from your fire and place it on the spot you want to carve out. You blow on it and the wood arround the coal starts burning. Once you have a nice spot all burnt out you just scrape it with a knife or whatever and then do it again. I found it much faster and easier than trying to do it with the knife tip. Less chances to cut yourself as well.
Am I the only one using this way of carving?Mikel
Mikel
No. I've used the "burn and scratch" method before. The spruce I was carving was pretty green and easy to carve, and I find it works better on seasoned dry wood.
I am sure this method works great for carving out pots and bowls... it is hard to carve the bottom of them by other means. Did you finish it up?SpookyPistolero said:Here's the beginning of a small bowl I was making.
Green wood helps out a lot, that's for sure. Do you guys fire harden the stuff you carve so it lasts longer or just use it as it is?Mikel
If you use a hollow plant stem for blowing, you can actually direct the burning action.
Doc
