- Oct 17, 2016
Damn sorry for beating a dead horse if this type of post pops up often.
I swear I need a prescription.It's ok, you probably just overlooked the last 10 or so in the past year.
Tip up for me. Not for ergo or quick draw reasons but because of where I like to carry my knife; right front pocket against outside edge. Tip up let's me keep the spine of the blade SAFELY pressed against the outer seam of my pocket.
All of my knives with clips are configured for tip-up carry. I'm sure I could learn to make deployment feel just as natural tip-down, but with tip-up I like the security of knowing that in the unlikely event the blade pops out in my pocket, it's up against the seam and has nowhere to go.
I've never bought a knife that could only be carried tip-down, and don't plan to. That could change for the right knife (the Millie has always been tempting), like any of my other knife preferences.
One of the littlest things I'm happiest to see on a knife I like, selfishly, is when it's only tapped for tip-up, right-hand carry, so there are no little holes I don't need all over the handle.![]()
No, see posts #8 and #13.
This is all posted light heartedly my friends.Thanks...was just trying to figure out if the "throw like a girl" thing was "sarcasm" too.
MaybeAquaholicc can explain it. Between that and the neanderthal thing there's a lot of similes in this thread and I don't want to miss any point he is trying to make.
Don't want to miss what he is saying.![]()
I never understood this arguement that only tip up (assuming right handed carry) gets the benefit of the pocket seam holding the blade closed. If you just move your tip down knife to the opposite corner of your pocket now the opposite seam (closer to zipper) will hold your tip down knife closed. Its only an issue if you are wearing those pants with diagonal type pockets like we find on slacks.
Yeah I spoke with my co worker about it and he adapts pretty well. Yes your adding another motion to the deploy but, like others have posted speed isn’t the upmost important. Hopefully I never find myself in a situation that seems otherwise.Your thread title should contain the essence of what it's about . Maybe get fewer grumpy posts from all these old burnouts .
I much prefer a waved opener , so mostly tip up . But , if speed is really a concern , diligent practice will allow most folders to draw fast enough . I still carry old models that are tip down only , with only mild anxiety .
Which type of pants commonly warn have no angle on the pocket that would allow what you describe? Is there a seam on the inside near the crotch?I never understood this arguement that only tip up (assuming right handed carry) gets the benefit of the pocket seam holding the blade closed. If you just move your tip down knife to the opposite corner of your pocket now the opposite seam (closer to zipper) will hold your tip down knife closed. Its only an issue if you are wearing those pants with diagonal type pockets like we find on slacks.
In regards to fluid motion, the aforementioned Millie positions your thumb exactly at the hole, when you draw.. When carried tip up, your hand is in a natural position to open the knife when you retreive it from your pocket. Carried tip down, you would have to turn the knife around first. Big deal? Not at all--simply an isuue of fluidity of motion.
I think whether or not this works depends on the pants/shorts you wear.
My jeans pockets have a curve in that spot, which makes knives hang weirdly. On top of that, there's a good 1" between the "corner" of that pocket on the outside and the actual seam on the inside -- plenty of room for a blade to accidentally emerge just far enough to snag the family jewels.![]()
^ any issues of that coming out of your pocket accidentally LD?
