- Mar 8, 2008
Even with a longer socket, they are lightweight sheet steel formed in the shape of a spear. They are fine for simple thrusting and some slashing but they simply lack the weight for much chopping. The same os true of the Bushman. There is simply not the mass.
I guess I just don't understand the fascination at times where any object immediately prompts a need to use one for something it was not intended to.. I suppose one could use a spear to drive tent pegs as well.![]()
In a related matter and circumstance, Victorian cavalry practiced tent pegging with lances from horseback but it did not relate using weapons for something they were not.
Cheers
GC
It may be light as compared to historical European spears, but that is not to say that it has insufficient mass to chop reasonably well when used as just the head. The key is to use it more as one would swing a machete, which may also be accomplished when the head is mounted on a short shaft. It's certainly not going to win any contests, but it works and is much more portable in that mode. The head may also be used much like a trowel for digging purposes if so needed. I actually have the drawings done up for a hand trowel designed for attachment to an extended handle for both improved digging as well as makeshift spear use. The need to dig almost certainly outdoes the need to use it as a spear in a modern camping/backpacking circumstance, so if it must sacrifice function in one way vs. another then rather it be a good digger and still a halfway decent spear.
