Spec Ops sheath?
that most certainly did
thank you
wish I could take the Esee pouch and sew onto the Spec Ops sheath and combine the two...
I might have something for my wife to do
The belt loops work great as molle attachments.
It does not. The pouch is relatively small. Itll fit the ESEE firekit and Exotac Matchcap with very little room to spare.
With the ESEE Firekit in the pouch.
With the Exotac MAtchcap in pouch:
Hope that helped.
Why does Guyons pouch look so much more stuffed and full? Like it has been expanded even farther?
I now have 2 x 6" Combat Masters, 1 for the BK2 and 1 for the RSK Mk2. My wife's BK2 just arrived Friday and I gave her the choice between the stock sheath of the Gen2 BK2 or the 6" Combat Master and she chose the original, so the RSK Mk2 got to keep it. I have 2 x 8" on order for the BK3 and the BK7.
Maybe cause he stuffed it with an item, that exactly matches the pouch's internal dimensions, thus utilizing it to its fullest? We'll find out when Guyon chimes in.
They make a great sheath for the BKs. I have visited their manufacturing company in Monahans, TX, and they are great bunch of guys. Very knowledgeable and ex-vets. There are two sizes 5-6" & 7-8" and recommend the combat master sheath, has the pouch for other items. I have their sheaths for my BKs - 2, 10, 7 & 3. Can get them with differ camo themes as well. I picked up this info from an ebay description listed below. This should address any spec questions you may have. I would go to their website Best Made Designs, check it out, email them or call.
The "COMBAT MASTER" utility knife sheath was developed to be the answer to a need from the field: Safely and securely carry the operators blade as well as be able to easily adapt to all M.O.L.L.E. type (PALS webbing loop) systems as well as duty and pants belts. The COMBAT MASTER is the only sheath commercially available that was specifically designed to accomplish this feat. Fully jumpable and over-built, this is the essential sheath for your combat blade!
Specifications
Fully adjustable utility / tool pouch. "550-cord" tie-down and leg-loop rigging.
Unique "MULTI-FIT" KYDEX® liner securely holds the following blade widths and thicknesses (removable for cleaning).
Long fits blades up to 8” Long x 1.75” Wide x 0.25” Thick
Short fits blades up to 6” Long x 1.75” Wide x 0.25” Thick
Tie-down loops on underside. Web loop at bottom for tie-down to packs, leg-loop, etc.
Extra durability with double-layered 1000D Cordura® fabric used throughout.
Mil-spec. Grommet tie-downs along sides of sheath body.
Jump-ready with redundant tie-down for knife handle and additional secure-down points along body and backside of sheath.
Backed by Spec.-Ops. Brand’s unique lifetime guarantee.
all of Guyons scales are the same. the dude mustve bought every pair of Camillus Micarta ever made
I want to know how he stuffed the compartment of his Combat Master with what looks like a lot of stuff.
very old thread but wanted to know if Buck 119 fits good I this spec ops combat sheath? Thank you
I'll ask a Becker question. Does anyone know if the combat master mini would fit a bk16? Anyone have any pics? I worry that it would rattle. I have the combat master short for my 10 and I love the quality.
It tends to be best just to buy the sheath intended for the knife. No issues can come from it that way.
The Combat Master sheaths have a kydex inner lining. You can remove the liner, insert your knife and pour boiling water over it. The kydex will soften and fit you knife perfectly. Leave it to cool with the knife still in it, and you'll have a rattle-free perfect fit.
