Specialized pocket fixed blade suggestion...help
My current EDC is a CRK Wilson Combat Large Starbenza. Since I have young children I cannot believe how much I actually cut up food on the go. I do not like using my main EDC knife as it typically dirty. I would like to get a small pocket fixed blade to ride along and be on food prep duty. Does anyone have any suggestions? I prefer it be of a stainless steel as it will be washed frequently and pocket sized, as well as uncoated.
Most Mora models would serve you well, as they are cheap yet very competent.
Personally i have been using a Mora 2000 for this purpose since 2006.
Get a stainless izula? Look in the custom fixed blades section? There are some very nice smaller fixed blades there for very reasonable prices often
seriously, if you go up to 100$ in budget, get one from one of the knifemakers on the board. just got a nice little aeb-l knife which should arrive any day for 70+shipping.
or get a stainless kids - my first opinel. i know, it is not fixed, but it is extremly pocket friendly and none threatening with that rounded tip (basically like a folding butter knife).
:thumbup:
I've seen small few "Bird & Trout" models that seem to be what you're looking for.
Otherwise, Zyliss makes a sweet paring knife that I use constantly in the kitchen. Thin, holds an edge, and easy to keep razor sharp.
While it's not fixed, the Opinel is a great option for pocket carry, since the twist lock makes it pretty much a fixed blade, but you also don't need to deal with a sheath. Also, it's dirt cheap and has a great food prep-style blade.
What I dislike the most about fixed blades is that I'll have to clean them before putting them back in their sheath. If your typical high end folder has some dirt on it, it won't touch the liners due to the washers and blade profile and even if it touched the liners, they're quite easy to clean. Not so much with the sheath of a fixed blade... at least IMHO.
Lionsteel 571 or 573
Simple design but still sharp appearance with a satin 440c blade; won't break the bank for a specialized tool, but still get Lionsteel quality.
How about an Opinel or a SAK?
Rich
I can't better Rich's recommendation. One advantage to a SAK, is the mirror polish on the blades, which will not tend to harbor bacteria as readily as a non-mirror blade finish.
An opinel has been used for food prep by the French for generations. They must know something.
A stainless Izula would work great. So would one of the many offerings from BRKT. I use a Bradford Guardian3 with A KSF pocket sheath. Works great and highly recommended.
I haven't had mine very long, but the cold steel Pendleton Mini is stainless steel (VG-1), uncoated and about 6" overall (not the newer, coated, 3V version that's not available yet).
Ti is a great material for the tasks you describe. Daniel Fairly makes a Ti blade called the Backpacker that I think would work great for you. Here is a pic of my DFK Backpacker next to a GEC #15 for size comparison.
Stabman and Average Gimp are way out in front of me.
AG Russell Woodswalker. AUS-8 is perfect for this size knife. It'll hone right up to razor edge and really resists stains and corrosion.
Get the leather hip pocket sheath AND the kydex neck sheath. I'll bet you never stop carrying it around.
This:
http://www.agrussell.com/ag-russell-woodswalker-in-leather-hip-pocket-sheath/p/AGPRS/
End thread. :D
Man, someone already said so...I should have read better. :)
So, I'll just to agree with them. ;)
I came here to post this, was not disappointed. Its available with a back pocket sheath, or kydex.
Also, check out the Ag Russell bird and trout. Its a bit over 3in, super light, and very thin.
You could also spring for an opinel #112 (its their paring knife). It is under $10, and is just a non folding opinel. I use these in the kitchen, and have actually been wondering how it would work in the outdoors. You'd just need to figure out a sheath.
Good luck :).
