Joshua Fisher
- Mar 27, 2018
Just a tip for those with metal saws, lower tooth count is going to work better for what is essentially a small resawing cut. You can find bi-metal blades in 4 and 6 tpi that are 1/2” wide from places like bladeserpent either in Lenox or their house brand. If the teeth are too fine they will clog before they can exit the cut and cause drifting as that dust has no where to go it pushes on the blade and will make the blade wander more. With the right blades you can make very thin cuts and have minimal clean up. If you only need to make one cut to split the block in half and don’t have a fence for the bandsaw use a height gauge and scribe a center line or scribe two lines and stay in between them. Oscillating tools in my experience build up a lot of heat in the cut which is not a good thing for wood handles, especially some exotics can be very sensitive to heat.
