Spyderco, Carson, and others
Feedback: +217 / =0 / -0
Under 25 feedback score ships first
Properly pkgd a must
Cash can go either way, i'd rather have cash come in than go out
USA only pls
I reserve the right to deal with whomever i please
Pics upon serious request- I'll need your email address to send pics
Open to just about any blade or accs in same price range
1. Begg Kwaiken- Dark grey/blackish frame, blade is dark acid wash. Has been used once by first owner to cut up some veg. Has not been carried or sharpened. It's unregistered too. Comes with everything from the factory. Strong detent, blade snaps open, no blade play, centered blade. The best fit and finish on a mid tech i've ever handled GONE
2.Spyderco Persian 75mm- Black micarta scales, stainless bolsters. Few light scratches on the bolsters, nothing unusual. Has not been carried, used or sharpened. Lockbacks still stiff. Comes with correct box, it's a little beat up TRADED
3.Ti Nives Stars and Stripes Forever #51- 3.5" satin blade, 7.5"OAL. . button lock. No play in any direction, blade is very slightly off centered. Opens smoothly and easily, closes under it's own weight. Comes with case
4.Extrema Ratio OPERATIVO 39-09- 8" N690 blade, 1/4" thick stock. 12 1/2" OAL. Has not been carried, used or sharpened. Some coating wear due to sheath insertion. Comes with the best sheath i've handled. It makes the knife. Secure blade securely, has snaps and a cover to ensure blade can't come accidently
5.Tank knives- 4.25" 1095, 1/4" thick. Handles are distressed ti. Monster blade. Weighs over a pound, but can be flicked open easily using the thumbstuds. No blade play, solid lockup, no stick. Comes with huge skull bead shown in pics. Clip is attached by one heavy duty screw that's easy to remove. Lanyard is attached to the clip so in one easy motion you can pull the clip and the lanyard
6.Fairall Model #3- 3.75" hand rubbed s30v blade. Swedge has 1/4"ish sharpened at the tip. Tan and blue g10 scales, comes with a set of cocobolo scales too. Has extra hardware too.
Detent is on the lighter side. Requires a firm push of the thumb or flick of wrist to open via the flipper tab. It can also be opened with the dual thumb studs. Has been carried 4 times, cut arm hair to test the blade after i sharpened it. Fairall no longer makes knives, so this is definitely a collectible. Comes with soft carry case
7. Crawford Shark- 4" bead blasted blade. Handles are ti, steel lockbar insert. Lockup is good, no play up and down, very slight flex side to side. Previous owner carried it a handful of times, i have not carried, used or sharpened. Has the original edge and is shaving sharp
8.Crawford Hawkbill Intregral -3.5" bead blasted blade. Handles are made from one piece of 1/4" thick 440C. I have carried it twice, has some minor snail trails. Snaps open with authority, very sharp.Has the original edge
9.Carson Sm m16- 3" combo edge, assymetrical grind, Stellite 6k blade. Handles are ti with a stainless lockbar insert. It's been carried three times. No blade play in any direction and it's centered.
Very smooth opening and very sharp
