- May 19, 2008
I would say the Military is the flagship model.
I think that's accurate. Coming in second IMO, based on popularity, I'd say the Paramilitary.
:thumbup:It's the smoothest knife I've ever experienced, including many of those big name semi-custom/semi-production knives out there (I won't name names b/c I want to keep this about the Spyderco GB). It is the sharpest knife out of the box I've ever experienced. The CPM M4 holds its edge for a VERY long time. The carbon fiber is both gorgeous and utilitarian at the same time. The overall fit and finish are some of the best I've seen on any knife, including knives that cost 3-4 times what the GB does.
As far as the rust goes...I've had mine for over 2 years and carry it often, including the high humidity/high sweat time of summer. I've never had a single spot of rust on it due to the fact that I wipe the blade with Tuf-Glide every couple weeks or so, as needed. The performance of CPM M4 far outweighs the corrosion potential, IMO.
The Military is indeed the flagship model. Such a shame that the GB is not fully flat ground. For that reason I got the ZDP-189 Stretch II instead.
~Paul~
How does GB´s carving capabilities compare to opinel´s?
Ooops! Just saw that tread is from 2012.
Dont worry, not that bad of a thread. Here it is with some use:
Gayle-Bradley-Hard-Use
Compared to an Opinel, dont expect magic as is from the factory. The Opinel is far thinner behind the edge and will out cut most knives. However, once you drop the edge angle on the Gayle Bradley to 10 degrees or lower it really comes into its own but still offers higher durability then an Opinel IMO at similar angles when it comes to sideways loads.
I am currently sharpening the Gayle Bradley to as low as angle as possible, basically sharpening it as a straight razor with the shoulders of the hollow grind as my guide and have yet to experience any issues, but it is an ongoing experiment.
Could I sharpen GB to 10 degrees with sharpmaker. I know that its made for higher angles but it should be possible.
Does anyone have other Taiwanese Spydies with f&f as good as the GB?
My Chaparral and Sages are terrific, but not quite up to the GB, IMO.
i have a question guys....... so between the Gayle Bradley and the Paramilitary2, which one would you consider as Spyderco's flag bearer?
~Paul~
