- May 2, 2006
Nice review, although none of my Militarys (I had 3 or 4 at one time) would stay locked.
Bad luck, or really hard spine wacks?
I just thumb-flick mineI just go my first Mili (in orange). It is huge but that is okay. I has a very arched handle which will take some getting use to. I never understood the advantage of that shape. The BRKT Fox River is similar in shape. Lock is very solid. And by the way, you can flip the blade out with the correct motion. Hold the back half of the knife with the hinge pointed up and away at about a 45 deg angle and your arm bent close to your body. Extend your arm sharply down and away, then stop and flip the knife back with your wrist. Short quick motion.
I have seen mild forms of this in just about every linerlock and framelock I own (excepting my Sebenza and Militaries).
If you go through this thread, you may notice something interesting. Comments such as blade misalignment, factory blade dullness, obvious scale gaps during production. I know that Benchmade makes good knives and I like them also but......... Why are buyers willing to put up with this sloppiness, and fix these knives after purchase instead of demanding that the manufacturer pull up its socks?
Well Benchmade was always listening to those problems. It is about six years ago as i received a completly new 806D2 without having to send back the defective.i live in Europe and shipping back & forth over the pond is kinda prohibitive
plus there is also the 'joy of tinkering'![]()
The axis lock is stronger, if the axis bar travels forth enough on the tang. My 520 did fail too. Compared to the 550, the axis bar was just half way up the tang. And, the tang has a higher angle in comparision.Most people believe that an axis lock is stronger than the liner lock. However, I found my BM520's axis lock to be weak. I did a spine whack test out of curiousity, and it failed. The blade closed even from light whack. After inpecting the 520 for a while, I found out that the axis lock does not work well when there's dirt (or lint) jammed in the locking mechanism. This never happened with my millie.
Again, I speak solely based on my own experience.
although I generally agree about Axis being stronger, still, the Military lock seems plenty strong to me
IIRC, the liner lock found on the Mili is rated as Heavy Duty (over 100 lbs per inch of blade length - as per Spyderco's internal testing)
plus, Sal stated before that Spyderco pays a premium for a G10 that has 30% more glass fiber than normal, in order to compensate for nested liners
