- Dec 10, 2021
thanks for playing
Everything breaks if “used enough”.It was an issue. The old ones it is said will eventually break if used enough. Not if but when (exceptions don't count.) Spyderco did change the type of plastic used on later versions to something better that it is supposed to be adequate. I do have more piece of mind with springy titanium being used for that part.
Was it? Where's the uproar? All the threads? Pics? Youboob outcry? Spyderco changes things all the time (it's called CQI). Just because they improve something does not mean the old was inadequate.It was an issue. The old ones it is said will eventually break if used enough. Not if but when (exceptions don't count.) Spyderco did change the type of plastic used on later versions to something better that it is supposed to be adequate. I do have more piece of mind with springy titanium being used for that part.
I just don't like the feeling of plastic on my knives.
Until it does break, it’s just an assumption. My guess is the spring would break before a molded piece of plastic. But the attitude that the neato anodized titanium ball cages are “better” are how aftermarket companies make more money. Imho get it for the neat colors, but it doesn’t improve the function of the knife. In fact, I’d argue it is more likely to be more of an issue due to metal parts sticking and needing oiled periodically. No one needs to oil plastic.I replaced mine, better grip.
Did it need it? No. I just wanted it to be metal, and it matched the rest of the knife. (G-10 not LW)
As much as I fidget with mine, the ball cage is what would break IF something did.
Just like the scales on some of my knives, needed? No. But I wanted them.
This is a fix looking for a problem. Total non-issue.
Then don't buy them. Plenty of info out there so you know if you are getting plastic or not. Also plenty of knife options with no plastic at all. I personally have come to prefer frn over other materials for edc knives. I don't knowingly buy other handle materials and then bitch that it isn't frn....
I did say it was an assumption.. I just wanted the metal cage. I wanted the FEEL of metal not plastic.Until it does break, it’s just an assumption. My guess is the spring would break before a molded piece of plastic. But the attitude that the neato anodized titanium ball cages are “better” are how aftermarket companies make more money. Imho get it for the neat colors, but it doesn’t improve the function of the knife. In fact, I’d argue it is more likely to be more of an issue due to metal parts sticking and needing oiled periodically. No one needs to oil plastic.
