- Nov 27, 1998
I couldn't be more impressed with the workmanship on the Southard. It's right up there with a lot of ~$500 customs in many ways, and from what I can tell, the consistency from sample to sample is excellent; e.g., every one I've handled and every photo I've seen of the lockbar shows the same tang engagement. It flips every bit as smoothly and crisply as my Todd Begg Gent's Glimpse IKBS custom.
On the down side, like many modern knives these days, this thing is seriously overbuilt if efficient cutting is your primary goal. IMO, this would be the perfect modern EDC utility knife if the blade stock thickness was cut more or less in half.
I was reducing some heavy (250 lb. test 'C'-flute) corrugated boxes to recycle-bin-sized pieces this afternoon, and decided to split the job between the Southard and a GEC lockback with a thin 1095 blade, and the latter blew the doors off the Southard. It glided through the corrugated like a laser, whereas the thick blade of the Spydie displayed a lot more resistance while dragging all that needless bulk through the material. In fairness to the Southard, the GEC's edge needed a quick touch-up afterwards, while the Southard was still out-of-the-box sharp when the task was done.
I also noticed a couple of sharp hot-spot points on the G10 scale at either end of the ball-milled groove surrounding lock release cutout, but that's an easy fix.
