UPDATE
Contacted spyderco for a repair and this is what I got...
"There is no way to repair the detent ball in the knife you have as we do not stock all the repair parts for the knives that are not made here in Golden and we do not use the same detent ball on the knives that are made here in Golden."
I have no response...
Wow so if you buy a non Golden Spydie, you basically have no warranty...? Besides catastrophic failures/issues obviously. Makes my Slysz Bowie a little less appealing...![]()
I'm honestly considering this. If you don't mind, could you check is your XHP techno has a flattened detent ball? hopefully the screeching will go away with more use...
That was surprising to hear about the lack of parts at Spyderco Golden to repair the Techno. I wonder if that means they would have replaced it if the warranty was still in tact?
That sucks. Spyderco really should be using a ceramic detent ball if the hole is blind like that. My Spyderco Southard did the same thing, but it had a thru hole and I rotated the ball.
I will be following this thread very closely.
Kershaw and Buck are looking better and better every day........
UPDATE
Absolutely.
OP, reply back and ask specifically for Charlynn (say: please forward). Insist on sending it in so they can check if the knife is within spec. If there is something really wrong with the detent, she has the means to at least try to repair it or she will have to send you a brand new replacement.
These posts saying that only Golden Spydies are covered under warranty is over the top and borderline BS. First off, all Spydercos come in the same box that states the same lifetime limited warranty. I've never had to send in any of my Taiwan models but have sent in a total of two Japanese Spydies both being Caly 3.5's. One was replaced with a brand new knife, the other I received MSRP credit value. While it is true that the warranty department cannot realistically hold all parts for all the overseas model knives both current and disco'd over Spyderco's thirty year history, they should still have several ways to make things right.
Warranty is no good since he took the knife apart. My Techno is working well so far.
