David Martin
Moderator
- Apr 7, 2008
Yep, I use oil on mine and it cleans off real easy. I carry mine in the same original blue plastic box and it does not have oil inside this box. DM
Mossyhorn
As FortyTwoBlades clarifies above "Use oil one time and it's an oil stone" doesn't apply to nonporous stones, and if it did you could still use one side with oil and the other side dry.
India stones are in a totally different grit range and are not interchangeable with sintered ceramic.
Cutting fluid is not only for cooling but also lubrication, and this applies to manual grinding too as others have stated in this thread, and elsewhere e.g.
Lol. I was a machinist and toolmaker for more than 20 years. In my experience, Mr. Wiz's assertions are dead on target. The reason he mentioned India hones being different than fused ceramic hones Moss, was not because he thought you didn't know they were different, but because you seemingly asserted that once any hone is used with oil it must in every case henceforth be considered an oil hone. That is absolutely not the case with fused ceramic hones. Washing them off is about like washing off a piece of glass.
He and you thought wrong. Read my original post and you will see that I was quoting Baryonyx.
Only 20 years, you're hardly an expert.![]()
We agree to disagree.
Mar 8, 2008
