- Jun 22, 2003
mete said:Seth , throwing in a few comments - Dirty steel refers to a high amount of inclusions , which are oxides or sulfides. A steel that is vacuum melted or even double vacuum melted has the lowest amount of inclusions and is very important for such things as bearings so BG42, a bearing steel ,will be very clean. Application determines the need for cleanliness......Vanadium in amounts of less than 1 % is added to refine the grain, not to produce carbides....... Are they saying Busse knives are nitrided ? that is a surface treatment like carburizing .In any case the Ti is probably there to form TiN, titanium nitride which acts like a carbide ( it's the gold stuff they coat drill bits with ). I haven't used one of those knives so I don't know how "fantastic" it is but I don't see anything in the composition that would produce miracles.
very good to know
when i said nitrided, i used a term that i didnt mean to, i just meant that it had nitrogen in it, not that it was coated.
when asked wether or not infi would benefit from the powder process vs smelting, jerry replied
Jerry Busse said:Matti S.,
Good question! We have explored this very question. Powdered metallurgy can offer some very strong benefits in certain ares of knife performance. However, it is not possible to take the same analysis from a smelted steel and transfer it to a powdered construct and achieve an improvement. Carbide dispersion is very good and can therefore greatly affect the amounts of carbide formers that are included in the mix. If we wanted to achieve the same level of performance as INFI in some areas, the analysis of the PM would look nothing like that of INFI.
Thanks,
Jerry
while there may be inconsistancies in the steel, on a whole i beleive that busse knives does more or less everything they do because they have found that it is best for the end performance of the steel. it may be that whatever is required to even out the grain sizes would be detrimental to the other aspects of the knifes performance.
Blop said:I just look at the research and made my concusion.
I guess, at that price range, where you pay double for one you can give such a warranty. Go break yours, will you?
And having handled a few i strongly belive, if they are sold hioghly it´s just for the name.
i bought my first busse after reading all of cliff stamps reviews refering to busse combat on his website. i would still do the same in light of those reveiws, and the things i have seen him do with a swamp rat/busse combat blade.
i dont think that the difference between a busse knife, and another knife of the same size and a high quality steel will or does feel fantastically different in use, but you do see it in the long haul. kind of like a car that you buy, and after 5 years, is still running like the day you got it, where as all of your other cars have had 10% of their components break or be replaced. that car probably doesnt handle any better, or get any better gas mileage, it just tends to break down less.
i agree that the knife (57rc edge and 60rc spine) should be sent back to busse combat, it would be replaced
im pretty sure that you could make a knife thats considerably stronger then infi out of a different steel such as L6, it just depends on what you need it for, and why you would need the added level of strength (at the cost of other areas of performance). and then theres the price factor...
