How much is wood too hot in Celsius ? I m searching for thick acrylic glass ... another one PicassoPulled vacuum for 8h this time. Left over night. I think the wood was too hot from oven when I put it in the epoxy, and it shortened the window. I think that an appropriate term for this morning action is clusterf**k.![]()
How much is wood too hot in Celsius ? I m searching for thick acrylic glass ... another one Picasso![]()
MY carta as a byproductHere are the pics.
And mycarta as a byproduct
MY carta as a byproductLooks excellent , why you didn't prepare the canvas this time to use the excess epoxy ? I think that I will pay beer in Wien , you just give me some crazy idea......
Mixing carbon with epoxy and then filling mold and then in press is messy job . NOW , what if I fill, press pure carbon in mold and then use vacuum as it is wood ? Several small holes in mold i hope will do the job ......
Fredy , I work on my setup for stabilizing wood and i just get idea .....IF you don t plan to sell stabilized block of wood , why you not first finish the handle on knife ..i mean complete work , handle glued sanded to finish and after that you stabilized wood? Whole knife in vacuum ? It will be faster , less epoxy and probably 100% penetration of resin in wood ?I did prep the byproduct, look at the white bottle next to the wood
But I missed the window now, at least for the red epoxy so there was no epoxy to use. I had prepped 3 pine cones in small plastic bottles and wanted to mix both epoxies together so its all black and then pull vacuum shortly on the cones. I managed to almost cover one pine cone and that was it. I didnt pull the vacuum cause the epoxy was too thick already...
I was looking also were to get carbon fiber sheaths, I think pressing it in wood press with epoxy would work. Pressure chamber would be better ofcourse. I fear that only vacuum would raise the sheaths when the air from epoxy would be pulled. Now imagine adding some aluminium or brass shaving to it as well.![]()
