You are welcome, but general consensus(in relation to corrosion resistance at least) and what I see on the web, is more like good/bad type of assessments. How do you go form that to the number with decimal point precision? I'm not trying to put down your work or flame, but giving numbers with such precision implies rather solid data behind them, otherwise it's quite misleading.
While it is true that it may not be a pin point precision decimal rating. But if 10 sites say H-1 is more resistant than VG-10/154CM/440C, wouldnt you be inclined to believe that it holds at least some truth? As mentioned in the methodology section of the post, the rating is based on the rank of corrosion resistance of a particular steel when compared to the other steels in the chart. It is not based of numeric value determined by a test. Except for hardness which I take Rockwell averages of different knife makers, and Edge retention which I have pulled data in from CATRA tests resources.
Again, thanks for your feedback.
