Has anyone thought about h1? It doesn't tend to chip, instead it rolls. Even if it does chip, It can be sharpened out easily and in that process, due to the properties of h1, the edge work harden very slightly. Thoughts?
There is nothing easy about sharpening a chip out of H1. Theres a reason they dont come in any FFG varieties.
And that reason is production costs.
Heiheit said:Sharpening h1 is very easy. It slowly hardens; it's not like it starts at 58 hrc and at the end of the sharpening it's 65
Correct. Due the the properties of the steel, one of them being the stress it imaprts on grinding tools to produce a FFG, they arent produced in that style.
Sharpening is no big deal, but when I thnk of a chip that occurs due to a blade coming in contact with a relatively hard inanimate object, I think of a large chip that takes a bit more than a couple passes on the stone to remove. Removing large edge damaging chips from H1 is a lot of work. Although I havent had years and years of experience with H1, I would assume that after 100 sharpenings the chips would be more frequent and harder to remove. And again, I think we are talking about a very small percentage point of hardness being gained over a very large amount of use and sharpening. I think very few users would actually be able to provide actual empirical evidence of such. Sal however, says it happens and I believe him.
....someone else said in their experience with H1 that it's edge retention started out like aus8 and after use and resharpenings ended with edge retention similar to vg-10. I don't know how much truth in that there is but I've heard similar reports.
Yeah Ive heard pretty much the same thing.. Ill tell you what, AUS-8 isnt that impressive, so anything better than that is a step in the right direction.
I completely agree. But if it is close to vg-10 with the corrosion resistance, it's a real winner. I'm always on the lookout for new user reports and tests on H1.
Steel capable of taking glass/metal contact?
Are there any steels that can handle contact with hard materials well? I'm not talking about consistent contact, but I keep having situations where I run my Kulgera into something hard, and the S30V takes a good beating. It holds an edge for a while all the way down to 20* inclusive, but I've started putting a 30* microbevel on it to deal with edge dings and nicks.
I haven't heard a lot about D2 except that it's very hard, should I check it out? What are some of the "harder" steels that can take rough stuff like that at an acute angle?
:thumbup::thumbup: on hardheart's answerno knife edge geometry is going to take this unmarred.
Is there Steel capable of taking glass/metal contact?
No, there is not. Not if you want the blade to have a knife edge.
...to deal with edge dings and nicks.
Stop hitting glass and metal.
all i know is when my zdp189 caly hit metal chips went a flying.
