Geometry and Heat Treatment.
Geometry - even a thin strip of pot metal cuts better than a block of S110V.
Heat Treat - inferior steels with the right heat treat can outperform superior steels with the wrong heat treat.
Yes me thinks also. :thumbup:+1, That's a Bingo!
This.Steel and heat treat, I can take care of the geometry.
Although, if you get a good steel, with a good heat treat, you can usually change the edge geometry to suit your taste.
Perhaps the OP could correct me if I'm wrong but by geometry I didn't think we were taking about the angle of the edge or secondary bevel. That is in most cases is easy to fix. I thought we were taking about things such as how thick the blade is directly behind the edge, and how rapidly thickness increases from there? These issues are much harder to fix for an end user and IMO prevalent on a lot of modern knives.
Geometry covers the whole. Blade. From the secondary grind to the primary. Thickness, location of the tip. The whole enchilada.Perhaps the OP could correct me if I'm wrong but by geometry I didn't think we were taking about the angle of the edge or secondary bevel. That is in most cases is easy to fix. I thought we were taking about things such as how thick the blade is directly behind the edge, and how rapidly thickness increases from there? These issues are much harder to fix for an end user and IMO prevalent on a lot of modern knives.
Then again what one person sees as a good steel someone else sees junk. Guess you can't please everyone.
