It's a pointless question. You need all three.
Pick two: brain, heart, blood. Any choice leaves you dead.
If heat treat, steel composition or geometry are only a little off, not a problem. If if you have big problems with any of those three, the knife is worthless.
I disagree.
This thread is about HAVING to pick 2 of the 3.
If I HAVE to pick 2 out of the 3, I will pick the two I can't change.....
There are a few very talented craftsmen that can change the geometry with precision, they cannot however, change the steel or the HT.
My two examples above, and these are not wholesale changes in geometry, but if I wanted to, it could have been.
Both knives have perfect regrinds from tip to scale, neither had even bevels from the factory. (Not many production knives do)
Both of those knives, while not known in standard form to be anything close to "slicers" will out slice any FFG Spyderco.
I got to keep the steels I love (CPM-154 and 20CV) lost zero toughness, as there was more than enough left behind the edge for hard use, and personally, I have not found better HT's than what Strider or RHK can do, considering these are not custom blades....
If you Mic'd these blades, you would see just how exact everything is.
You have 15DPS (Strider) and 18DPS (RHK) from tip to scale.
You have 0.20 behind the edge's from tip to scale. (Actually, the Strider has 0.25 at the tip, for more strength)
The primary grind is Perfect throughout the entire regrind.
You don't get this in a production knife.
