Sal Glesser
Moderator
- Dec 27, 1998
Hi Cliff,
The goal would be to just provide the "stuff" at an affordable cost.
Scientific testing could be done by those smarter with a greater understanding than me.
That's your job.
We (the industry) would certainly benefit from such results.
I am aware of the testing that you wish to do and the outline that you presented. I would be happy to try to accomodate your requests, but I couldn't provide different steels at one time.
To try to do a small number of blades (10 - 20) made from different steels would be custom work and would run $200+ per blade, assuming you could get small quantities of the steels.
Assuming 3 blades per lb. of steel, 500 blades (already quite a few) is only 200 lbs of steel. Most foundries won't even talk to you for 200 lbs., much less make a 200 lb. run. So a fair amount of "romancing" might be necessary to be able to get the material. If the steel is $15/lb. like some of the exotics, then we've got $5 in raw steel without shipping / receiving costs.
Different steels have different heat treat requirements. "batch" heat treating cannor affordably be done on 2 or 3 blades. Grinding times are different for different steels based on their abrasion resistance, so batch grinding is also out on small numbers. Set up times are expensive.
We would have to be able to schedule the runs in alongside of our regular work. Sales and distribution details would have to be worked out. Maybe though one person? If you get too many people involved, or profit becomes an issue, the affordability goes away.
We did a run of "swicks" a while back. That was kind of an experiment to see if this type of thing could be done. We provided a "slip" sheath, but even that adds cost.
We could connect you guys to our sheath maker, who could make up slip sheaths in some type of volume to save the costs of custom sheaths and get us out of the middle.
The same could apply to scales. We would provide consistent holes in the handle or skeletonize for fastening or cord wrap, but someone else would provide scales or do the wrap.
It's also possible that there wouldn't be enough interest to warrant the project. We would have to do one to see. We would want to move all inventory on one run before beginning the next.
sal
That's your job.
sal
