What in taking away from the ops post is he is wanting a 1 handed operating knife (which most all kershaws do). And that he just wants one tool, given that he probably knows multitools exist and he did not ask about them. I'm also getting the vibe he's ok with wearing out a knife and replacing it and that he would prefer to go a longer period of time without doing so.
With those criteria I would take a look at a bench made adamas, non assisted would be at the upper tier but you probably wouldn't break it doing what you describe. Also I would echo aus8 cold steels in the recon or voyager lines or a voyager in bd1 if you want to save on price.
Edit: since it's a homestead situation a fixed blade would also be pretty appropriate and an esee 4 is pretty bomb proof for the size.
I would say get a multi-tool
Then for a pocket knife get Ontario Rat 1(AUS 8 is a good stainless)AUS 8 or D2. Spyderco Cru-Wear, Benchmade Griptilian in M4.
You definitely don't want to pry with a cutting tool. A multi tool has enough pry-able tools on it to be handy. Or get a little pry tool and a pocket knife for cutting. Multi tool would be much better for cutting wire as well.
I daily carry a Kershaw with a 14c28n blade material, I'm finding the material to be too hard and snapping for my utility work. I have around 5 moon-shape chunks out of the blade. I use this blade around the homestead so it's for cutting rope, wire, prying out staples, digging out nails in wood to get to them with a hammer, and just general utility usage. I've had it since 2013 approx. so I've gotten a lot of life out of it.
Holding a razor sharp edge isn't as important to me as not breaking / chipping.
What kind of steel should I be looking for that fits my general utility need?
I'm looking for a folding knife. I'm not stuck on '1' brand. Ideally $150 or less since it will be 'abused' by most standards
Thought I'd add that 14c28n is in the AEB-l family of steels it's Sandvicks upgrade to 13c26 which a copy of Bohler Uddeholm AEB-L but with a slight carbon drop replaced with nitrogen added to improve the corrosion resistance. Might even be tougher.You might look for a knife with heavy blade geometry. Sharpen it to more than 40 degrees inclusive. Good tough steels are 3V, Elmax and ABE-L.
Sounds like you need a thicker knife behind the edge with a very step edge.
Those SOG wire cutters aren't all that good. They are OK for anything other than steel, bailing, or other harder wires. Copper, thin electrical, phone, are fine. Anything larger will bend the hell put of the jaws.
If you want a multitool, get one with replaceable hardened cutters. I think the OHT has them, as well as some other Leatherman's.
Neither are the Gerber's.
