- Dec 21, 2006
LOL, I read the post, scratch my head, and said to myself, "What?" Good to know I'm not crazy, or if I am, there are others out there!
No one is asking you to refrain from posting about topics - we simply don't understand what you're attempting to accomplish. This has nothing to do with you being mad or thick-skinned, and it has nothing to do with the "established KM world".
Nothing in your posts could be construed as insightful. If you're trying to discuss factual information, don't require your audience to "read your post carefully and between the lines".
Can you explain what your end goals are, and what your methodology seeks to prove?
John Nash whaaaa????
I'm interested in your trial and error testing, so long as it's actual tests, not abstract communication of ideas going down the proverbial rabbit hole... It would be easier to digest if your intentions were followed through with a legitimate experiment, utilizing the scientific method. Lay it out for everyone else in those simple terms, as I will second the notion that your posting is "out there" (which, if I'm saying that means you're "really-really OuT ThEre")...
I'm interested in learning, my mind is an open parachute.
Oh, and I love that avatar... One of the best fruits I've ever had the privilege of eating... filipino ba?
And also, you said, "Set up high and ultra high carbon as low carbon" what does that mean? Are you saying that you are trying to make a hypereutectoid a hypoeutectoid for some reason?
Bluntcut, I think you are misunderstanding some of the simpler principles while focusing on the more complex ones. This is common with out of the box thinkers (I'm one too, and have to remind myself this all the time.) You cannot take the composition and calculate what you will get in the end, as the matrix can get complicated and compromised. The industrial heat treat recipes have been tested to get the best percentages of the elements where they are needed. Straying will either not get the elements into solution, or inversely get them to move to places where you don't want them, such as in grain boundaries, or in overly large carbides. Quenching at rates outside of recommendations, will stress the matrix, and cause microfractures throughout the steel. None of this is good for the properties we look for in blades. You are focused on carbon, but vanadium and tungsten are valuable carbides as well. They help with wear resistance, which you are looking for. Getting them into solution properly, and distributed evenly in small carbides will be your best bet. Reading your posts, I think a steel like 15N20 would be your ideal if it came with 1% carbon. The nickel would give you some toughness, and you could push the Rc# higher than typical. Would there be an advantage over W2? Probably not.
Carbides can also be pulled out of the matrix, especially if the matrix is messed up from improper heat treat/quench. Small, evenly distributed carbides in a relatively stress free matrix are what we try to get. In other applications, such as bearings, larger carbides can be an advantage, which is why there is a range of HT for 52100. Higher austentizing gives larger carbides and results in retained austentite, which is easily dealt with in industrial applications. These traits are not advantageous for a knife. I suppose if we were rolling steel balls over our knives packed in grease it would be good, but that's not what I intend my knives to do.
I find even my lowly 15n20 kitchen knives get stropped every week or so, and re-sharpened every 2-3 months, with daily use. This is the low end of my wear resistance. What more do I need?
Based on some admittedly old (40 yr+) research, finer carbides are better even for bearings of 52100. Higher austenization results in smaller carbides, or none at all. This is one of the issues with knife maker terms vs. industrial terms. One of the reasons for normalizing is to get rid of all the carbides, at least in low alloy steels. All the carbides are dissolved and reform smaller later if treated properly. Knifemaking normalization is just a heat to 1420 to 1500 and air cool. That may or may not dissolve all the carbides, depending on steel.
