**A tip of the hat to Blues Bender---and Maybe this will help, Jmunson.
My solution (below) to releasing a frozen CKF Sukhoi pivot (non torx side only turned in sync with the torx side when I tried to disassemble the knife...All originally posted in this thread-->
http://www.bladeforums.com/forums/showthread.php/1302384-CKF-Sukhoi-pivot-(unscrewing-it)-question
--> Ok, first, I don't recommend that anyone do what I did. I was determined to find a solution, even at the cost of (possibly) damaging my knife (a little). Thankfully this worked out beautifully...no damage...vast improvement on knife's action.
Here's the abbreviated versions because I hate to type out novels.
1) I had my trusty bottle of Goof Off solvent ready to go.
2) I heated the pivot with a hair dryer at close range, set on high. It got the knife surprisingly hot within about 30 seconds.
3) picked up knife in a small hand towel as it was HOT...positioned it with backside/female side of pivot facing up
4) applied a TINY DOT of Krazy Glue to edge of backside pivot screw and affix it to carbon fiber scale with said dot of glue
5) waited 15 seconds for it to set (but pivot to remain hot)
6) flipped knife over, inserted torx driver & prayed
7) push torx bit in deep and turned it hard (but controlled)
8) pivot screws released from each other!!!
9) quickly began the process of using Goof Off on a paper towel to dissolve/remove dot of Krazy Glue as much as possible before complete disassembly and the COMPLETE removal of any remaining bit of any remnants of Krazy Glue on the Carbon Fiber & edge of back pivot screw (female side)
10) NO damage to carbon fiber or pivot screw
11) This Krazy© process allowed me to hold the backside screw in place securely enough to separate the two halves of the heavily (Loc-tied together...or whatever the Chinese or Russians use) pivot screw, male from female.
12) Immediately drank one shot of Patron Silver to calm down and celebrate my success and lack of any damage to the knife.
13) Cleaned out, Nano oiled relevant areas, greatly improved the action of this MRBS knife.
14) Reassembled meticulously. Flipped, Flipped, Flipped!
15) Moved on with life with great sense of satisfaction and accomplishment
Good luck to anyone who decides to undertake this potentially risky method. It worked for me. It was the only method that worked, of all I tried.
