Walt, yes, however consider the knives that the Chef's are using as baselines and consider further how those blades would be judged here. I know a couple of chefs and they don't have high end custom knives. Everyone of my blades that I have shown to them was met with rave reviews - some on blade that I felt were substandard - but then again my standards are far above Henckels (Wilson, Boye, Schott, Busse etc. ) :
The Talonite (r) chef's knife was used for disjointing chicken and ducks, and for preparing lobster. Not just for cutting soft stuff.
Assuming you know how to and where to cut, disjointing small (and large) game does not produce significant stress on the edge of a knife. As for lobster, if they just split the tails and back, that is not hard either. Again, assuming they know what to do and the cuts are straight and forceful. If they cut/chopped up the claws (never seen that done), it would be fairly impressive.
Gator :
I suspect Talonite won't perform as well as high end steel o hard materials, such as bones
Depends on what steel. I have for example chipped out a Dendritic 440C blade with some very light work around bones, yet a Stellite 6K blade can be intentionally cut into and torqued while in the bone. It is far more ductile and less prone to snapping (Talonite it similar). However, there are steels that can do similar and are stronger and more compression resistant as well.
Cobalt :
Cliff, I want my knife back in one piece!!
The only way to damage that blade as far as I can tell would be either (a) heavy prying, (b) really hard impacts [bash it full force off of a rock].
I thought there was a possibility of breaking it with hard wood chopping, simply because I hadn't used one in that configuration. But I spent several days with Will's blades chopping up a lot of wood (about 10 k chops with each). With no functional damage. However the blades are really light. In a full bowie profile I would be curious if the same would be true.
To tell you the truth I don't even think that (b) would actually do much based on what I have seen with my Talonite knife. However, I don't intend on trying either with your blade. I might see how mine responds to very high impacts as compared to some steel blades with Cougar is finished with it.
-Cliff
[This message has been edited by Cliff Stamp (edited 09-27-2000).]
